Samsung SP42WHBX Projection TV No analogue sound
Barry
Sep 12, 2007, 2:45 PM
Post #1 of 6 (108 views)
Samsung SP42WHBX Projection TV No analogue sound Can't Post
Hi I have been given the above TV, it previous owner (My younger brother) decided it would be a nice idea to perform a reset in the service menu having got hold of the service manual.
I have managed to sort out the convergence although it is a little out of position ,Blush (only noticable when veiwing a bottom of the screen cable menu) though i still cant get it to auto converge
The main problem is that although I get sound from cable TV and DVD, connected by scart. I get no sound at all from an analogue TV signal from the aerial. I guess it is a setting in one of the sub menus (i have the default factory settings and the listing of the headings.
If anybody feels they could help it would be much appreciated and i would be happy to email the relevant service manual file (828kb zipped)
It is an old TV now and i don't think it is worth getting an expert to sort it out as the cost would be more than its worth. But it is a personal mission nowSmile
Sep 12, 2007, 3:39 PM
Post #2 of 6 (102 views)
Re: [Barry] Samsung SP42WHBX Projection TV No analogue sound [In reply to] Can't Post
check its not set for eastern European sound in the menu
Barry
Sep 13, 2007, 5:22 PM
Post #3 of 6 (95 views)
Re: [techchris] Samsung SP42WHBX Projection TV No analogue sound [In reply to] Can't Post
Thanks for the reply, i just can't find that setting.
I tried individually adjusting System to CW, Swapping from nicam to dolby, none of which solved the problem.
http://filesco.com/download.php?id=93A5CE811
The link is for the service manual,now i found somewhere it can be hosted.
Sep 13, 2007, 5:46 PM
Post #4 of 6 (90 views)
if you are in the UK the system is pal I not D/K .should be in initial set up menu.
Barry
Sep 14, 2007, 12:54 PM
Post #5 of 6 (84 views)
Thanks for that,
The channel autostore (Country)had changed so i changed it back to UK and searched for channels again. Problem solved. Never though to look in the standard set up menu.
Now if i could just work out why the clock loses its time every time the tv is manually switched off I will be set.Sly
Sep 14, 2007, 1:52 PM
Post #6 of 6 (81 views)
some tv's have no clock retention when switched off at the mains.yours may be one.don't waste time finding a fault that isn't there. a phone call to samsung may tell you if this is so.
