Slight blue shadow? Help. Toshiba 43H70
Cobracapri87
Jan 15, 2007, 7:14 PM
Post #1 of 2 (284 views)
Slight blue shadow? Help. Toshiba 43H70 Can't Post
I just replaced the STK392-110's last week. The Tv is running great, and totally watchable. But I do get a slight blue shadow only sometimes when allote of white is displaying, it has a blue shadow to it. I adjusted the convergence by entering service mode with the grid, and the menu convergence adjustment. I also had to adjust the hight after the STK392-110 replacement. What can I do to get rid of the blue shadow? Thanks
Jan 16, 2007, 7:44 AM
Post #2 of 2 (267 views)
Re: [Cobracapri87] Slight blue shadow? Help. Toshiba 43H70 [In reply to] Can't Post
if the blue is flaring out from white objects then the blue tube is probably going.you could try altering the screen volts slightly to see if this improves things otherwise new tubes are required as its generally best to change all three together. make sure you are sitting down when you find out the price!
