May 4, 2010, 11:26 PM
Post #11 of 13
(7792 views)
Re: [chris17] Sony Convergence Repair - now TV won't stay on
One thing you might try (does not work on ALL sets) is to either "float" the pins of the ICs (or remove them completely). Clean the area with isopropyl rubbing alcohol or flux remover, then let evaporate. Try to operate set, and see if it stays on. Of course, the convergence will be terrible, but if set continues to run, pretty well proves ICs (or soldering) is cause. ------------------------- Location: Far, Far Away
