RetiredTVguy2
Aug 12, 2007, 6:57 AM
Post #3 of 4
(222 views)
Re: [mikemaiertv] Sony KP51HW40 Need tech help
Indeed you are correct, the fly was replaced, the original problem was it was totaly dead, also Q8035 Q8038 Q8036 and Q8037 (36 & 37 are surface mounted), After replaceing the fly Q8035 & 38 that restored power but it would still shut down with the LED code of 8blinks, then I replaced Q8036 & 37 which restored sustained power but the LED code x5. I did check resistors and diodes around all those transistors and the fly but will check again and focus on the ones you gave me to check, I also want to try bringing up G2 but Im leery about it because according to the manual the adjustment is done with a scope and a jig, which I do not have, the jig I could make but the scope.... Thanks for the tip, wish me luck! [retired] ---------------------------------------------------------- When everyone treats you bad, turn to your dog, he or she will understand! ----------------------------------------------------------- I dont mind working, as long as it doesn't interfere with fishing!
