Nagamitsu
Jan 16, 2011, 10:43 PM
Post #8 of 22
(5033 views)
Re: [jts1957] Sony Videoscope KP-53S55 no picture, but has sound
Thanks!!! Those are IC1701, 1702, 1703 Marked in schematic as R.SUB-AMP, G SUB-AMP, B SUB-AMP respectively. So that's Red, Green, Blue sub-amp. I see IC1706, 1707, 1708 on far left side of D board that are attached to heatsinks, in schematic as VR-OUT, VG-OUT, VB-OUT. So you are saying the sub-amp 1701, 02, 03 next to the convergence ICs should be the vertical. Easy enough for me to replace or re-solder at least. Phew. (except if I need to look into the jungle IC, which I'm hoping is on the E1 board that plugs into the A board, but I'm assuming that due to reference to "jungle" in the schematic) Tim
