Sony kp-46wt510 with 8 blinking lights
redcard
Apr 4, 2013, 9:02 PM
Post #1 of 8 (3145 views)
Sony kp-46wt510 with 8 blinking lights Can't Post
My sony tv has 8 blinking lights how do I go about problem solving and repairing this
Apr 4, 2013, 9:20 PM
Post #2 of 8 (3141 views)
Re: [redcard] Sony kp-46wt510 with 8 blinking lights [In reply to] Can't Post
Standby light flashing 8 times and TV has no picture or sound.
Checking CN8016/pin 3 on the D Board was going above 7.4v, thus causing
IC8008/pin 12 to put the set into shutdown.
Found HV Block was defective. Wink
redcard
Apr 4, 2013, 9:29 PM
Post #3 of 8 (3136 views)
Re: [jts1957] Sony kp-46wt510 with 8 blinking lights [In reply to] Can't Post
 hi thanks for the quick reply.
so how do I fix this. this isn't the power supply board, so the middle board. I've read that it might be the audio amp?
redcard
Apr 4, 2013, 9:47 PM
Post #4 of 8 (3135 views)
so the high voltage block is with the 4 red wires the ground pin and the clip going to i'm assuming the D board?
redcard
Apr 4, 2013, 10:59 PM
Post #5 of 8 (3129 views)
I've disconnected all wires etc to the hvb and tried the set to see about the set. it now gives me 5 blinking lights is this correct with the hvb removed?
redcard
Apr 4, 2013, 11:34 PM
Post #6 of 8 (3128 views)
I've tested pin 3 and there wasn't any voltage on it.
redcard
Apr 4, 2013, 11:38 PM
Post #7 of 8 (3126 views)
with the hvb plugged back in there wasn't any voltage on it
mosfett
Apr 17, 2013, 3:05 AM
Post #8 of 8 (3053 views)
replacing of the deflection circuit should restore operation,
