colker
Dec 17, 2006, 2:51 AM
Post #1 of 9
(599 views)
Toshiba 42h81 won't turn on
Hi all. My problem started with the blue being out of convergence, but escalated into the tv not turning on. The tv had the symptom of bad convergence ICs. The blue was separated from the red and green. The touch focus gave a "touch focus error" message. So I went to www.audiolabga.com and ordered 2 chips for $12 each. I was going to get the $6 ones from www.electronix.com, but people seemed to advise against those on here. Anyways, I disconnected all the wires from both boards (including the high voltage) wires before realizing that I only needed to get the convergence board out. So I put the HV wires back and took out the convergence board. I had my friend solder the new chips on (he has soldered many times and is much better than I am). After I got the board home, I connected everything into the proper places, although this was from memory as I did not take very good pictures. While I'm on this subject, is there a 5-wire connector the connects to P113 on the convergence board? I had no connectors to connect there, and I don't remember if one was there before I disconnected the board. After everything was connected, I plugged in the tv and...nothing. No click of the relay. So I disconnected a few wires, reconnected them, and plugged it in again. This time I got the sound of the relay. I looked and the screen and it was this horrible mess of colors and lines. I could not make out anything. On top of this, the remote control would not even turn off the tv. I manually turned off the tv and tried to turn it on with the remote. Nothing. So I turned it back on manually and started disconnecting and reconnecting wires (stupid thing to do with power going to the boards). Last thing I remember is hearing a click (I think it was the relay). Now all the happens when turning on the tv is the red light turns on and the relay clicks. Nothing else. Anybody have any ideas of what I might have damaged? I should have gotten the service manual before attempting any of this, but I didn't. By the way, does anybody have the service manual in pdf I could have? Thanks.
