MaierTV
Aug 9, 2003, 1:40 PM
Post #2 of 3
(2171 views)
Re: [Guest] Toshiba Projection TV TP55G90
One of the most common fails in the projection sets is there convergance Ic's either get cold solder joints making a intermitant conection causing temp. distiortions or they fail this leave a distorted pix that never changes and/or put the set in a safty shut down not allowing it to turn on. To repair or replace these Ic's depend where and who you call could be as little as $89 for a quick solder job to $400 for a service call ,replace Ic's and reset factory convergance. best bet call around
