Feb 10, 2011, 11:55 PM
Post #5 of 6
(3049 views)
Re: [BradC] Toshiba TN55X81 Convergance Problem
BradC;.... I have a problem believing his whole story.... In brief;.... I'm not challengeing that the ICs were good OR bad.... I strongly believe they WERE bad..... He said it can't be the B+ fuse because they are all there and that the Blue is fine. Because they were "there" doesn't make them good.... Thre's more than one fuse to check.... That's what a DVM is in part for.... Checking each fuse to see if it checks good.... As well as the resistors are fine because the colors are all there and if they were bad there would be no color at all or one of them would be missing. This in a word is pure unadulterated horsepucky !!! Convergence ICs have NO effect on color levels.... ONLY where each color lands on the CRT face which then winds up onscreen.... Do you believe this is true? My reply still stands;=>.... """MY best advice would be to call another GOOD , reliable , HONEST & trustworthy TV shop & have those parts checked out""".... Keep this in mind;...I'm NOT saying that the above IS your problem.... I'm saying that a complete convergence board is RARELY the problem & that the above parts should be looked at before you mount an extensive search & spend a lot of money for some board that may/may not fix the TV.... Your Call..... GOOD LUCK........ Later...Ron.M........ Veteran & Retired TV technician
(This post was edited by Ron.M on Feb 10, 2011, 11:56 PM)
