Toshiba ticking after STK fix
Strange
Jul 30, 2007, 9:08 PM
Post #1 of 14 (370 views)
Toshiba ticking after STK fix Can't Post
took it apart and replaced the stk's put it all back together turned the TV on and the picture looked ok and eveything and set the convergence. but there is a ticking noise. it sounds just like when your cars spark plug wire has a short so i listened around the flyback but it almost sounds like its past it and a little bit farther.
i also thought it might be the heat paste getting hot and poping, but its as soon as TVs on and stops as soon as TV off.
the picture also has slight im perfections in it that are very subtle. the ticking is pretty constant but occasioanly it will skip a tick and be quite.
what do you guys think?
TZ50V61 is the tv model
(This post was edited by Strange on Jul 30, 2007, 9:09 PM)
Strange
Jul 31, 2007, 11:35 AM
Post #2 of 14 (358 views)
Re: [Strange] Toshiba ticking after STK fix [In reply to] Can't Post
i made my self a little paper cone to listen in the tv to find the location (not about to stick a metal stephascope in there) and i narrowed it down to two circuit boards in the tv
theres the 3 little bulb projector curcuit baords on left center and right, and then right above the center bulb circuit board is another board, its one of the center boards
the center board has a small plug and set of wires running to each bulbs circuit board
wich one of these is my likly culprit to the ticking?
after listining very carfully it does tick a couple more time very slowly and faintly after tv is off
RetiredTVguy2
Aug 1, 2007, 3:46 PM
Post #3 of 14 (345 views)
When you say bulb's I think you are referring to the CRT's (picture tubes) there are 3 of them (red/gree/blue). Sounds to me like you have an "arc" and I have seen this happen to the high voltage anode's. It could also be in the socket on that small board (CRT board). This kind of repair I would refer to a master tech who knows more then me, so hang in there, hopefuly someone who klnows more about this will get back to you.
When everyone treats you bad, turn to your dog, he or she will understand!
I dont mind working, as long as it doesn't interfere with fishing!
Strange
Aug 5, 2007, 3:49 PM
Post #4 of 14 (332 views)
Re: [RetiredTVguy2] Toshiba ticking after STK fix [In reply to] Can't Post
any body got any hints tips, things to check for?
Strange
Sep 10, 2007, 1:36 PM
Post #5 of 14 (289 views)
well my other tv is starting to go out so i need to get this big screen working right.
whats a common thing on that central CRT controll board that can make these arcing noices?
terminator
Sep 14, 2007, 8:48 PM
Post #6 of 14 (271 views)
dude retired tvguy if this is a big screen its not a crt its a projection tv. okay strange there are three projectors in there that you think are bulbs they are called projection lamps if they go out the tv is toast the parts for older tvs are not avalable anymore.
ernie
Sep 15, 2007, 7:44 AM
Post #7 of 14 (265 views)
Re: [terminator] Toshiba ticking after STK fix [In reply to] Can't Post
i would imagine by now that people who look at these pages would realise that you are a moron.a retired tv guy and you a 15 year old kid thinks you can tell him and all these other tv technicians they dont know what they are on about that makes you a moron.a rear projection works on three projection lamps are you stupid why do you think they are called CRT rear projection tvs.i would suggest that before you come on these pages spouting your rubbish you should learn a hell of a lot more first and dont call people who was fixing tvs long before you were even born as you are just showing how much a moron you realy are
terminator
Sep 16, 2007, 11:54 AM
Post #8 of 14 (252 views)
Re: [ernie] Toshiba ticking after STK fix [In reply to] Can't Post
just shut the fuck up. i already told you and the others to not answer on my posts!
ernie
Sep 16, 2007, 12:43 PM
Post #9 of 14 (249 views)
and i thought it said reply at the top of your posts or do you want to pick and choose who does reply,you see the problem is that you are replying to other peoples posts who are relying on expert oppinions they dont know you from adam so they dont realise that you dont know what you are on about so other people have to take issue with you before a tv gets scrapped on the say so of a 15 yr old moron.if you dont want people replying to your posts then just stop trying to give people who rely on good advice your basic knowledge of nothing.
Sep 16, 2007, 1:53 PM
Post #10 of 14 (247 views)
Ive come across some imbeciles in my life Ernie, but that turnipator surpasses them all!!
ernie
Sep 17, 2007, 2:19 AM
Post #11 of 14 (240 views)
private message from a moron(you need to shut the fuck up about me or ill start posting things about you!).post whatever you like but why do it as a private message do it openly so we can all see what a moron you are
ernie
Sep 17, 2007, 1:49 PM
Post #12 of 14 (232 views)
Re: [techchris] Toshiba ticking after STK fix [In reply to] Can't Post
same here chris,hopefully that by now people reading these posts will realise he knows nothing and will ignore his posts that way he might just realise he is wasting his time.
Strange
Oct 23, 2007, 5:57 PM
Post #13 of 14 (169 views)
alright well i gotta get this tv working soon, my tv ive been using is starting to go out so its time for this big screen to quit taking and room and be a tv.
i talked to a tv shop and they said might be a bad capacitor, so i looked at all the capacitors on the 2 offending boads, none of them have buldging tops rust or spewed there guts...so that caps are good on the boards where the noise is from
another thing i thought of was maybe i got a slightly defective STK when i put the new ones in thats not quite doing its job, like telling the tv to do somthing it cant do outside its paramenters, cuasing a clicking, (anything like that possible?) the reason i thought of this is the tv will occasionaly pop out of convergence.
but maybe its the noise on screen cuase it to look like this,
if a crt is bad will it to click like this?
ahh im at my whits end. im just trying to provide you guys with as much info as possible to help me out.
thanks
dm1394
Oct 26, 2007, 3:21 PM
Post #14 of 14 (152 views)
Is it a High Voltage tick? Usually ticking on projection TV's after repair is associated with a ground that has been removed during repair and not replaced. Have you checked for loose or disconnected grounds to the CRT's or CRT Shield?
