johnfrank
Dec 29, 2004, 1:00 AM
Post #1 of 4
(3431 views)
Zenith E44W46LCD Audio Problem
I have seen several posts on this forum concerning Zenith E44W46LCD variable audio out sound level problems. The responses do not make it clear to me if the condition is normal or requires fixing. I will attempt to describe my experience as follows: I have a problem with the Variable Audio Output connection on the Zenith E44W46LCD TV. I want to use it to connect to my stereo amplifier to improve the quality of sound when viewing DVDs, CDs, VCR tapes, as well as TV. I realize that the intention of this connection is to allow control of the stereo amplifier audio using the TV volume control on the TV remote control. I have the TV Variable Audio Output connected to the Video input on my stereo amplifier (The other input is PHONO and is too sensitive). #1 The problem is that I have to crank the volume of my stereo amplifier up to maximum or near-maximum in order to have sufficient sound come out of the speakers. I input to the video connectors on the stereo. The volume setting on the stereo has to be at so high a level that if I switch between modes on my stereo amplifier (from video to either co or tuner) I fear I will damage my speakers because the level is too high for the tuner or co. Conversely, if I want to set the volume level on my stereo amplifier at a comfortable level, then I need to turn of the TV speakers from the menu and crank up the TV volume to get sufficient output to the stereo. If I turn the TV speakers back on at this level, the load to the TV speakers is dangerously high. Question: Is this condition normal? #2 When I set the TV Audio Speaker menu settings to "Center", nothing can be heard from either the TV or audio out speakers. Question: What should I expect to hear when the setting is set to "Center"? I would appreciate any comments on your experience with audio and center speaker conrol on this TV as I am trying to decide whether to exchange it, have it serviced or return it and shop for another HDTV. I really like everything about the E44W46LCD and would prefer to stick with it if I can.
