mikemaiertv
Aug 23, 2007, 5:34 PM
Post #2 of 22
(509 views)
Re: [jiggernaut] Zenith E44W46LCD Blue Screen Problem
Wrote this a few years ago::::: Got bad news, if you have been following this and I havent read all the post but if youre here because of the blue line on the bottom We now have a fix. All most all the repairs have been to change the light engine, thats a little spendy and some times this part is not avalible. Well with a few dozen of these complaints we finaly tore the guts out of one to find out why this happens, all we could find was the plastic on the engine distorts and changes the optics, This is not a simple fix and is quite involved but the basics go like this, Gut the entire front leaving the engine in the chassis, remove the LCD controler board leaving all but the LCD ribbons attached and move this to the left side. there are now two lenses, one with small shims on the left and one with big shims on the right rear. Loosen the screws and break them free Now the big one usaley has to go up a hair, and the little one down. You will have to take the button assembly,and the interface board out of the front and hook all this up just to turn the unit on, once you get that far make sure all plugs are in and then turn the unit on. Since none of the lcd's are hooked up you should have a white display, we simply stood the front screen verticaly along the left side so we could see what was going on, now you can shimm the lens's up or down to produce the best totaly white screen as possible. You may have to build some shims for the big lens, but on occasion the ones removed from the little almost get the job done. As you can tell from all that this aint no simple thing to do, but when out of warrentee and no parts avalible you do what you can. Also keep in mind Zeinth just hates you screwing with there light engines and will void any warentees real fast. Now all you have to do it put it all back together Also when we do this we notice some discoloration but discovered this all comes from the fact that all the shields are removed and the light box is reflecting it back, finding the best overall white works best. First time we attepted this it took hours, no wwe got this down to 45 minutes. just go slow and dont rip any ribbons Mike Owens Lead tech Maier TV Spokane Wa Mike Owens Lead tech Maier TV Spokane Wa
