mheim1
Jan 24, 2006, 3:52 AM
Post #5 of 6
(6030 views)
Re: [dandvd27] akai pt4298hd projection with red and blue lines
Danny, inside the TV you have to unscrew the board (one screw) and unclip all the connections; I believe there were 4 or 5. Some wires are already attached to the new board; so I just did one at a time (unplugg from old board, connect onto new board or unplug old wire, plugg in new wire). I just took a chance with a new board (cost me less or the same than have a repair guy check it), but I'm sure there is a way to measure those IC's; I believe I saw something in the Samsung post which described unplugging something else and look at the result. I was looking around for a repairmanual and could not find one (quit looking after I fixed it), but I am sure if you get one for a Samsung HCM 4216 it will be identical; try servicemanuals.net. As far as the arc'ing goes: I have no idea. I got my board from partstore.com ($87.63 plus S+H +T). Check out Samsung posts, as those are the same TV's. Hope this helps and good luck. Mike.
