Mar 3, 2012, 7:34 PM
Post #6 of 7
(2908 views)
Re: [mediadude2] arcing flyback zenith projection tv
mediadude2;..... You should be alright... Just to be 100% sure , when you disconnect the flyback lead , stay away from the metal end of the large red wire... Ground that end to chassis ground (Tuner cover is an excellent location) ... There most likely won't be a charge left on it after that length of time , but , I have seen instances where they did hold a charge... Better to be safe than sorry.... Good Luck with your repair......... Have a GREAT day & weekend....... Later...Ron.M....... Veteran & Retired TV technician
