need help for 61h71 toshiba
vin pat
Jul 14, 2007, 12:09 PM
Post #1 of 4 (131 views)
need help for 61h71 toshiba Can't Post
hello dear friends
Please help me to fix the T.V. 61h71 toshiba. because i see double picture. green color r very off .blue and red colors are in line up but green color is not in line i did try every thing to do but i cant' lineup green. i did try to do touch focus but it says " touch focus error". then i did try to do manuel but i can not do it because green color is way off line about 4 to 5 in. bottom side.
mikemaiertv
Jul 14, 2007, 5:52 PM
Post #2 of 4 (126 views)
Re: [vin pat] need help for 61h71 toshiba [In reply to] Can't Post
This is the most common problem of all projection sets, Lookup Convergance fail on this help site and you will find hundreds of posts, Then have the STK392-110 replaced because this is the problem
vin pat
Jul 14, 2007, 10:10 PM
Post #3 of 4 (121 views)
Re: [mikemaiertv] need help for 61h71 toshiba [In reply to] Can't Post
hi thnx for replay. but i am new in this kinda stuff so please would u help me to locate SKT392-110 where would i fiend this IC i know how to remove from board and solder also.thnx again
RetiredTVguy2
Jul 16, 2007, 6:57 AM
Post #4 of 4 (105 views)
Vin, I also answered you in the other forum so look there for some info. make sure the set is off and unplugged before going inside. Those STK's are the larg IC's usualy with about 18 or more pins.
Good luck!
When everyone treats you bad, turn to your dog, he or she will understand!
I dont mind working, as long as it doesn't interfere with fishing!
