Aug 10, 2010, 4:54 PM
Post #5 of 5
(1412 views)
Re: [shawn011] phillips 60pp920217f convergence problems
shawn011;.... "Houston , we have a problem".... With all due respect , you are dead in the water......... This repair requires some electronic/TV repair background.... There are 2 18 pin ICs that require replacement & most likely follow-up adjustments.... This is way more than a mechanical repair & plumbing soldering IS different than the soldering for electronic parts (Especially ICs) ..... Without any experience , my best reccommendation would be for you to call a good reputable TV repair shop for a hopefully free estimate , then go from there......... This repair should normally not be a major expense..... Depends on your location , etc.... GOOD LUCK.......... Later.....Ron.M........ Veteran & Retired TV technician
(This post was edited by Ron.M on Aug 10, 2010, 4:55 PM)
