diverd
Mar 21, 2005, 3:41 PM
(1180 views)
pioneer SD-p6091K **** Help ****
This is model SD-P6091K. This set is about 8 years old and needs to be repaired. It will work fine for a while and the picture will go black and the volume stays on after the picture goes out. If you turn on the PIP there is a picture and the volume bar comes on, also if you change the channel to one not being used and wait for the screen to go to staticy and then go back to channel 3 (using a cable box) the picture comes back, also turn off the set and turn it back on again the picture will come back on. The next problem is the blue is slightly miss aligned on the left side of the screen on the right and center it is good I would like to change the bad Ic chip. Any idea where I can buy the chip and the # for the chip would be great. Any Help would be great!!!
