crazidan
Jan 4, 2005, 8:39 PM
(1863 views)
rca 52 in tv wont power up
this rca is a ctc169pt power supply is running at 175 and the flyback running at 140v was working then went down now i check all the hz-output trans. ok check all diode and all the caps in the hz section it like the set is dead right now i push the power button nutting happen it is like it wont get out of stand by now i got the 5v standby at 12v the 13v line running at 12.9v the b+is 145v and the amp power lines are 16.8 v each i done found that cr606,q601 shorted i need a cross for it the unit tryed to turn on but stop and will not now tryed to get help form wa6ati but i think they are parts changer only not tech. if any one can help thanks now i put a 15v load to the 5v standby section at c610 was running at 12v seen some smoke now the standby is running at 5.6v i say it must of had a load on it?
(This post was edited by crazidan on Jan 12, 2005, 5:37 PM)
