kosmiko23
Jan 26, 2007, 1:27 AM
Post #3 of 3
(145 views)
Re: [Larry E] request about one fuse?? help pls..
Hi, it`s a 3 amp chemical fuse, if it`s open then it means there is a short on the voltage line it is supposed to protect, in other words replacing just the fuse is not going to fix your set, it will open again unless you find the part that is causing it to open. Mr. Harry Thank you.. I apreciate your help =.......
