samsung HCM4215W wont turn on
vgboris
Aug 16, 2007, 1:39 AM
Post #1 of 4 (304 views)
samsung HCM4215W wont turn on Can't Post
My TV wont turn on.When I try to turn it on,I hear clicks and the sound only lasts for a small amount of seconds.Please respond.I would be more than happy to hear from you!Wink
mikemaiertv
Aug 21, 2007, 7:15 PM
Post #2 of 4 (289 views)
Re: [vgboris] samsung HCM4215W wont turn on [In reply to] Can't Post
This uses the stand alone convergance board, it sits all by itself up above all the other boards and has two large Ic's ( STK392-040 ) unplug the extream left plug on this board. this takes power away from this board, now if the set now runs but with a distorted pix you found the problem, simply replace this board BP95-00142E at www.vancebaldwin.com about 80 bucks. This is not a fix all for these Samsungs but it is the most common problem. Before I leave, if the set runs and has a distorted pix, it simply means there no convergance correction going on, remember you un pluged the board, but if there is a line running up and down and possibley in two colors and looks like a burn mark,,,,,, it is,,, in about 30% of these sets when convergance fails it,,,,Well to make it easy burns the red and green crt beyond repair. so if you see this line stop right there, youre done.
adkhaja
Aug 23, 2007, 5:55 AM
Post #3 of 4 (279 views)
Would you like to tell what had actually happened?
Is it powered off slowly or at once?
it just might have a bad connection or the sensor on the lamp door might not be activated all the time....
check the manual and suggest you to go for some repair person.
here is some guide available might be helpful to you.
LCD Projection Tv sets help
ghafur
Sep 8, 2007, 12:28 AM
Post #4 of 4 (229 views)
It might be a lamp or ballast problem as ballast makes the connection with the lamp.
Have you gone for some tech person?
Check out the connections....
Regards
