yellow streaks on 42 " Samsung
brooker32
Apr 2, 2007, 11:57 AM
Post #1 of 7 (247 views)
yellow streaks on 42 " Samsung Can't Post
I have vertical yellow bands or streaks going from the bottom to about anywhere from 2- 8 inches towards the middle of the screen. I have a problem with the green convergence going back to September. I cannot adjust the green left right in convergence mode. I can adjust the red and blue to match it so that is not a major issue right now. The yellow streak however is very noticeable on white backgrounds like a hockey game. Today I removed the covers, cleaned the inside of the screen as well as the mirror and the lenses, but it didn't change at all. The model is Hc-P4241W. My IC's are STK394-250.
brooker32
Apr 4, 2007, 12:37 PM
Post #2 of 7 (237 views)
Re: [brooker32] yellow streaks on 42 " Samsung [In reply to] Can't Post
My IC's are mounted to the heat sink....how would I remove it to replace the IC's? Hopefully my picture will be attached this time. I also have a pic of the yellow line although it's a little hard to notice on this background.
(This post was edited by brooker32 on Apr 4, 2007, 12:44 PM)
Attachments: IMG_0107.JPG (801 KB)
  yellow streak.JPG (117 KB)
Apr 4, 2007, 2:49 PM
Post #3 of 7 (229 views)
just unsolder all the legs take out the screws and the ic will come off the board.make sure you use heat compound between the new ic's and the heatsink.double check the soldering for shorts across two pins after resoldering the new ones in to save having to take the board out again.the yellow smudges may be gunk in the crt coolant.look into the tubes to check to clear fluid not murky stuff.
brooker32
Apr 4, 2007, 3:06 PM
Post #4 of 7 (228 views)
Re: [techchris] yellow streaks on 42 " Samsung [In reply to] Can't Post
Is there a common way to check the CRT coolant or is it specific to each tv? I have an electronics background(photocopiers, faxes, etc,) but I have never looked at tvs before. Can you give me an rough idea how to check?
brooker32
Apr 4, 2007, 6:03 PM
Post #5 of 7 (224 views)
Well after reading the thread on replacing CRT coolant I believe I have bad IC's and bad coolant in my blue lense. I have included a pic. Has anyone replaced coolant on a Samsung 42" RPTV? Also this tv has tubing running to a bag hooked to the side of the tv frame just like a IV in a hospital. So I wonder how would I change the coolant with that type of setup?
Attachments: IMG_0136.JPG (1.08 MB)
brooker32
Apr 10, 2007, 12:08 PM
Post #6 of 7 (201 views)
Anyone?
brooker32
Apr 18, 2007, 12:17 PM
Post #7 of 7 (177 views)
I am going to attempt to change my coolant. Can anyone take a look at the picture I have attached and give me some guidance on how to do it withour removing the whole unit? Can I remove the lens first? If so will the coolant spill out? Which screws would I have to remove to remove the lens? Thanks in advance.
(This post was edited by brooker32 on Apr 18, 2007, 12:23 PM)
Attachments: IMG_0166.JPG (799 KB)
