SmokinBarrel
Sep 9, 2009, 2:11 PM
Post #6 of 15
(6449 views)
Re: [jts1957] *** HDTV Antenna - No Signal on HDTV? ***
Okay, I was able to hook up a small TV and test the system.... I used the HD converter and Small TV and did not receive a signal. Sooo, I am thinking about buying another antenna from Radio Shack versus the internet (ebay). What a joke.... I know people have had good luck with this antenna on ebay, but I am not sure what the problem is. Obviously, it doesn't like regular Cable Wire (satellite cable). Or, the distance is an issue. So, rather than dinker around with it any longer, I have decided to buy another antenna. Any suggestions on what I should get? Please remember: 1. I have 100' for the signal to travel 2. I will be splitting the signal for two TV's. (I have one HDTV, and one older TV w/ HD converter box) 3. The guy at radio shack (RS) said I should be able to hook up RS's antenna and it should work at 100' run. Note: I look at the TV color code sheet, and "Yellow uhf" is what I am most interested in receiving. BUT, I noticed that "Amplified" antenna's are not recommended for "Yellow" color codes? But also, if you plan to run longer than 20' w/ cable an amplified antenna is recommended. Ugh!
(This post was edited by SmokinBarrel on Sep 9, 2009, 2:25 PM)
