Tigger
Aug 15, 2011, 2:27 PM
(3815 views)
Re: [santa] 22" UMC power supply failure
This is way down the line from your original post so you have probably sorted things by now, but for anyone needing the info... I had the same problem with a LK1060 power supply for a Technika (Tesco) TV, 12volts on no load and down to 3v on load. After research found that a common problem is the two output capacitors 1000/16v elects (domed tops where they had swollen) replaced them out for £0.60 and saved myself a fortune
