timjamesz06
Jun 10, 2014, 8:54 PM
Post #18 of 20
(5133 views)
Re: [flyatyou66] 42" Toshiba Plasma - Y-Buffer or Bad Screen?
That's kind of funny, that part you linked to is sold by payless components, where I always buy my parts from anyway. But I'm a little confused by your following comment. You're saying digital board, as in the digital signal board, correct? Not to be confused with the d-board (which according to my service manual is the name for the logic board, ie the post LVDS logic board that sends the signals to the Y-SUS and Z-SUS and data drivers). To be clear, I have replaced the digital signal board in the past (it ended up not being necessary but it was first attempt to fix an unrelated problem) without replacing any other boards and the set worked fine (artifacts were present, but otherwise fine). And I have never replaced the seine board on the tv. But what you're saying, if I am interpreting this correctly, is that if you replace the digital signal board, you must also replace the seine board (the analog signal board) or the digital board 'will not work'. This is certainly not the case based on what I have done in the past. The digital signal board definitely 'works' unless you consider the presence of these artifacts 'not working'. Moreover, I don't understand why replacing both boards together would be necessary, at least not for digital signals. The digital signals never back up into the seine board according to the block diagram. Heck, I can (and have) unplug power to the seine board altogether and the picture stays exactly the same. Regarding the menu, yes the menu comes up and looks fine, but that is not to say that the problem isn't still present on the menu objects themselves (since the artifacts only show up on very particular circumstances, they could easily still be present on the menu items and just not visible because of the colors/brightness of the menu items). All that being said, unless you think it will be a complete waste, I'm still convinced that the only thing to try at this point is to replace the digital signal board ($25), and if that doesn't fix it, then it's most likely the screen itself or something else that I'm not going to figure out without replacing and swapping lots of boards. Worse case I can resell the signal board for a slight loss. The deal I was trying to get for both the seine and the digital signal board together fell through (guy wanted $55 bucks for both, which is a good deal, but just isn't justifiable to me especially since I don't think replacing the seine board is going to help at all). And regardless what someone may say about replacing both at the same time, I'm going off the signal block diagram, and I don't see how the seine board affects digital signals entering and leaving the digital signal board directly unless someone can elaborate on this and explain in detail why they must both be replaced. To me, that just sounds like someone's way of getting you to buy two replacement boards when you may not need both. Hope I'm not coming off as an a**hole, and I truly appreciate your research and help on this. But the service manual doesn't state that both boards have to be replaced at the same time, the block diagram doesn't show anything to support it, so I need something more to go on before I believe it. If that is the case, why would toshiba ever have sold the boards separately?
