505Choppers
Aug 21, 2006, 11:18 PM
Post #1 of 3
(1059 views)
43uwx10b Hitachi Power Problem...
Tv worked great as far as picture and sound when it was on, then it had a power surge, turned off and would not turn on again. Well I followed the "protection" start up where you turn on, then 30 sec later then unplg 30 sec and then on and it Worked. Now we had another power surge and it died for good, will not power up. When I hit power it makes about 4 clicks real fast (within 2 seconds) turns on front RED led for about a second and the leds (green multiple and a red one that fades away slowly) inside the cabinet go on for a slipt second as well. Anyway to bypass the surge protectors in these or any way for me to test voltage to know if its the power supply? Its about 5 years old and worked flawlessly until the power drama, any help would be greatly appreciated. Im above novice , but not a repairman, Im an auto mechanic, so I can handle taking the power board out and checking things with an ohmmeter, thanks again.
