Jan 16, 2012, 8:28 PM
Post #7 of 7
(2496 views)
Re: [discretesignals] Alternator regulator operation
discretesignals;.... 1st , I need to clear up something , then I'll give you some info from Basic Electronics 101 which may enlighten you & correct some errors in Alternator 101..... Concerning;=>... If the blue wire is back probed, there is a reading of 8 VDC. This was taken from an operational charging system. WHERE are you reading 8 VDC at ???...& HOW ??? & PIN 1 Blue wire .5 VDC Pin #1 on your schematic goes to the base of TR1... (That schematic may not be entirely accurate).. TR1 appears to control TR2... TR2 appears to be controling TR3 & turns the lamp on & off... TR3 is the transistor that provides current for the rotor coil... The more current thru the rotor coil , the higher the output at "battery" connection , giving you a higher charging rate... The 0.5 vdc coming in on Pin #1 IS your control voltage for the rate of charge.. If & when it changes , the rate of charge changes... I have some reservations as to how the alternator was tested... Bench testing , to me , means the alternator is capable of charging a battery... That , again to me , does not prove that the regulator circuit IS working... I am concerned with the voltage on Pin #1... IF the battery is low & needs charging , I would think that that voltage would change... Your problem could be the PCM is not working properly... I don't know what TR1 is doing or those diodes including the zener. I know that diodes are one way check valves and a zener is a diode that blocks current flow up to a certain point. TR1 already explained..... The zener allows a set voltage to pass thru... In this case it apparently is set at a level that when the voltage from TR1 goes higher than what the zener is designed to handle , it passes that to TR2 which in turn conducts... When that voltage drops to a level that the zener blocks it , TR2 is turned off & your lamp is turned offf... The service information doesn't say what these values should be or what a waveform pattern should look like. We really need to get hold of an oscilloscope and monitor these signals to see what they are doing on a good vehicle. I personally do not think a "scope" is going to be of any help... Reason is that you are working with DC voltages & scopes are designed to show AC signals... All you'll get with DC is a flat line possibly with a little ripple that could be used to measure DC volts... The service information says that the PCM monitors the amount of current change when loads are put on the alternator (cooling fans, ac compressor, etc.) from the FR circuit (blue wire) and uses the G (ground) circuit to control alternator output. Some identity confusion here.... According to your info , the "Blue" wire goes to Pin #1....("PIN 1 Blue wire .5 VDC" )... It is marked as "C" or "G" on the schematic... It is NOT "ground"... It IS the control line from the PCM... The metal case that all this is in is the "Ground"... The "FR" line is pink & goes to Pin #4...("PIN 4 Pink wire 12 VDC") IF you read 8 vdc on Pin #1 on a car that has a working charging system & 0.5 vdc on a car that is not charging , then the obvious conclusion is that possibly the PCM is at fault... GOOD LUCK..... .... School's out.... .... Have a GREAT day & week.... .... Later...Ron.M.... .... Veteran & Retired TV technician
(This post was edited by Ron.M on Jan 16, 2012, 8:30 PM)
