Apex AT2704S Turns on and off rapidly
adrenalin
Jul 8, 2007, 7:31 PM
Post #1 of 5 (212 views)
Apex AT2704S Turns on and off rapidly Can't Post
Hello Everyone, I am studying to be a TV Repairman and have run into something i have never seen before.
I have an Apex Model# AT2704S 32" TV and for some odd reason when i plug it in, it will turn on and off very rapidly. I opened it up and tested everything i could and found only 1 capicator needed replacing. I replaced it and it still does the same thing.
Now to remind you!!! All i have to do is plug it in and it will turn on and off very rapidly by itself without even physically touch the TV at all.
Any assistance on this would be greatly appreciated.
addy
(This post was edited by adrenalin on Jul 9, 2007, 8:18 PM)
adrenalin
Jul 9, 2007, 8:26 PM
Post #2 of 5 (200 views)
Re: [adrenalin] Apex AT2704S Turns on and off rapidly [In reply to] Can't Post
I went ahead and decided to check and see if it was the power button. I removed the power button from the board and it still did the same thing.
Something else i need to add is that when i plug it into the wall, it will click like it is trying to come on and then it will click and then start the cycle again. Click on and then click off. Even with the power button completely removed from the unit. I went through the whole board again ohms testing everything and everything is just fine.
This is turning out to be a big issue and hopefully someone from here can point me in the right direction.
I really do not want to give up on this thing, due to the fact that i think that it will bite me in the end and a paying customer will have the same issue and i will not be able to help them.
Thanks,
addy
Jul 10, 2007, 12:32 PM
Post #3 of 5 (188 views)
ther is a short circuit somewhere which is shutting the tv down. disconnect the HOT and see if the 120 volt line starts up feeding the HOT collector.if it is there then the transistor could be shorted or the flyback transformer faulty, or both.
jayede
Feb 17, 2008, 4:18 PM
Post #4 of 5 (112 views)
this is the first time i have ever posted on a forum so please be patient..i also have an apex at2704s series television 27in. that was made in 2003 and has a mind of its own..it not only turns itself on and off but it changes channels too..sometimes it is constant and it ignores the remotes and manual buttons at the tv..i thought maybe someone was playing a joke on me but that seems not the case..please help..desperate to fix problemUnsure ..p.s. need info put in terms for dummies Blush
dont know if this matters..10-c chas ?
(This post was edited by jayede on Feb 17, 2008, 4:29 PM)
jayede
Feb 18, 2008, 8:17 AM
Post #5 of 5 (105 views)
hello again..dont know if this made a difference but i got really upset with the problem i was having and i threw the remote..the batteries were really hot and the tv stopped the channel surfing and turning on and off..so i am assuming it was the remote that caused my problem all along..
Search for (options) Web Design by Web Ideas - Page loaded in: 0.22 s on (CGI/1.1)
