tscheucher
Jul 15, 2009, 7:15 AM
Post #7 of 26
(11806 views)
Re: [vorp] Audiovox Plasma TV Fuse Blown
Hi vorp! Audiovox is a non common brand in Europe and only to purchase via online distributers. You posted some very conclusive images of the power pcb which let me think of a product from DELTA Electronics from the far east. At first sight I assume that the fuse is linked to a schottky diode (mounted at the black heatsink at the side) at the supplyīs secondary output (somewhere between 12 and 24V) which is saving it from short circuit deaths due to overloads. The first thing in such cases is to figure out if something is shorted at the main pcbīs power input (the board the graphic/upscaler, memory and software icīs are located) or the voltage inverter board. Itīs mostly triggered by bad electrolytic capacitors or shorted mosfetīs on the inverter caused by bad inverter transformers. The fuse fu503 itsself is a special construction due to save production costs and to allow the power supplyīs operating IC (SMPS - IC) taking measures of current consumption as a feedback for checking the deviceīs health status. They just took a fusible resistor for that job. Itīs value isnīt that important as long as it doesnīt exceed 10 Ohm. In your case, and obviously without a service manual, I would recommend you to take a 3,3Ohm carbon film resistor with 0,25Watt as a replacement. Itīs value is low enough for passing a high current and to blow again in cause of persisting short circuiting. If it blows off again, immediately unplug your set from the mains and take measures for short circuits, as I mentioned before, on the main pcb and the surrounding area of the blown fuse on the power supplyīs pcb. Make sure that there are now bad solder joints or leakages within switching rectifiers (diodes) and replace the 3 electrolytic capacitors close to the fuse just precautionary. According the photo you made, their value must be somewhere around 680 - 2200uF and 25 -35V. I will try to get a schematic and will announce again, if I didnīt get positive feedback from you (If your tv is still on strike...). Good luck! TS
