marty_dawson
Jul 29, 2004, 8:03 AM
(2126 views)
Re: [drvstrnz] Blown fuse in convergence circuit
There should be 2 2A 'picofuses', F701 and F702. The originals are rectangular, black w/ axial leads, but any type pico or pigtail fuse will work if you can make it fit. They fuse the 32V and -32V supplies for the STKs. If either are blown, one of the STKs may be shorted to ground, if one's bad I usually replace them both. However I have one right now that makes the R/B (front) STK run hot and will play about 30 min before knocking out the -32V fuse. Toshiba told me to check all the 2.7 ohm 2W resistors, I've checked them twice and can't find any out of tolerance, but they claim that can cause STK and fuse failures. I think the one I have has a problem with the drive input, just ain't figured it out yet. Hope yours is easier than this one
