daveb
May 1, 2012, 12:20 AM
Post #9 of 22
(10840 views)
Re: [Ron.M] Bush mk92nw won't respond to remote
daveb;...... I'm presuming the remote IS the ORIGINAL that came with the TV... Correct ??? I'm not the slightest bit familiar with "Bush" TVs , just Presidents... The "Blue" LED flashing tells me that the Micro IS getting the pulses from the remote... They may not be the right pulses transmitted by the remote but close enough for the Micro to respond... Your remote could still be bad...Unsure... And more seriously , the Micro could be bad....Unsure... Do you have a "menu" button on the set ??? IF so , see what's in the set-up section... In particular, Child Lock , Parental Control (NOT the Viewing Ratings type) , or anything that suggests a disabling of the remote... Hi Ron, thanks for the reply. The remote is the original. I went into the menu via the button on the set. Checked the various things it could be that are preventing the remote from working (parental control, channel locks etc etc) and found nothing to suggest that the remote should be blocked, as all the boxes were left unchecked. It's also worth mentioning, that once i enter the menu via the set, i can navigate myself round the menu using the remote, but as soon as i exit the menu the tv instantly refuses to cooperate again!!!! I press a button, and the light flashes, but nothing happens.
