alvarinb
Oct 18, 2017, 3:06 AM
(710 views)
CRT TV!! KV36XBR800 Progressive scan problem
Hi, I bought this TV for the only porpoise of retro gaming but I have 2 problems with it for which I need all the old experts help. First Problem: It takes several tries to turn it on but when it does you can turn it on and off again with the remote no problem. I have no idea when it looses the ability to turn on again but after a while it comes back to the same problem. Second Problem: When I use component cables with it and play some progressive scan games (original xbox) the colors are all wrong, as if it wont detect the red or blue because everything is green. But when I use the same component connection with SD signal the colors are ok. I've already changed the Board M 1-684-695-13 or A-1300-320-A and the U Board following some advice but it didn't work. PS: I'm no expert, I just need to know if it can be fixed and what parts to buy. Thank you!
