t0nito
May 19, 2016, 6:22 PM
Post #24 of 24
(3797 views)
Re: [Ron.M] CRT Vestel 11AK37-8 Shorted HOT replaced, still shorted
Hey Ron. I only read your reply after I actually fixed the set. I received a new HOT today I installed it and desoldered the B+ from the flyback and connected a 150W bulb in series, the HV fired up and the bulb lit dimly, I put a 60W bulb, HV fired up and the bulb was dim, though brighter, I put in a 40W bulb, HV fired up again and the bulb was dim as well. I took a shot and resoldered the flyback pin. TV turned on as normal. I left the TV on for a few seconds and touched the HOT, it was completely cold. I then left the TV on for about 20 min, the HOT was barely warm. It's been on for over an hour now, so far everything's fine. My conclusion, the original HOT shorted due to a cold solder joint on the capacitor. The replacement HOT was a dodgy dud as it shorted in a split second. I'm gonna leave it on for a while before returning it, it has an awesome picture! Thanks guys!
(This post was edited by t0nito on May 19, 2016, 6:35 PM)
