jerryp49
Apr 22, 2005, 9:18 PM
Post #6 of 12
(1610 views)
Re: [mel] CTC169BJ2 from PS35652 no 5v Stnby
Thanks for the help Mel. I just got back from the parts store and got the replacement for the Q4105 Zener (1N5365BP2 36v 5w). It was going weak but not shorted. I did get the 5vdc stand-by going earlier with your suggestions. It was the CR710 and CR606 that had shorted. Now I'm trying to jump the next hurdle. If I bypass the the on off switch by cold grounding JW336 (like the computerized schematic suggest for testing) all I'm getting is a fast ticking of the relay but no start. All of the B+ voltages take a dive when this is done I already replaced the HOT again as a precation, but no change. I've been going through all of the transistors, diodes, caps and resistors but haven't found anything else bad, other than the Q4105, which made no difference. The schematic tells me that I should have 5v ant the 'C' of Q4304 in the off setting but there is only 1vdc. I've tried to trace out this drop but can't locate it. Any other thoughts? Jerry
