nicolas.tam
Jul 30, 2020, 6:18 PM
Post #1 of 3
(1158 views)
Change panel of LED tv
Hi, Ok so the panel of my LED tv (Samsung UE32j5500) got damaged, and shows two noticeable impacts. I then by chance found the exact same tv (used) for a cheap price. But with that one the backlight seems to be very low. The settings of both sets are exactly the same but the one I just bought is much less bright in comparison, with duller colors, and has some slight clouding in one of the corners. So my question is, can I just take the panel of the tv with the backlight issue to replace the panel of my original tv (which works perfectly apart from the two impacts)? Will it fix the issues I'm having? Thank you.
(This post was edited by nicolas.tam on Jul 30, 2020, 6:38 PM)
