crawdaddy
Feb 10, 2005, 12:35 PM
(1266 views)
Re: [bobcat] Dead Magnavox Please Help!
Since you have a map, first thing is to locate the output of the power supply to determine if there is any life there at all. You're looking for the B+voltage (it may or may not be regulated at that point). I try to measure across the main filter capacitor terminals(carefully, of course)...if you find voltage there, move on to the collector of the horizontal output transistor.. the B+ should be there, and the horizontal section must be working for anything else to happen.. I'm not familiar with this chassis, so these are just some things to try that you might look at with any set. Perhaps someone with experience with Magnavox will be of more help...in any case, good luck, and please post back with the outcome....
