Mar 30, 2005, 2:26 AM
(1483 views)
Re: [Kyle_South_Park] GE 27 inch TV
A model number would help but the two screws above are probably UHF antenna connectors if the set is quite old. You will only get the UHF channels there. The coax connector can be replaced but if the set is that old, it is probably not worth bothering with. If you would like a free new set, check out www.FreeFlatScreens.com/?r=10948674. with a little effort on your part, you can earn a new 27" Sony Vega as I did.
