May 6, 2020, 3:00 PM
Post #4 of 4
(1086 views)
Re: [jackemiller] Help. Panasonic pt-51hx41e not powering on
SERVICE NOTES: This model has section that does not share a common ground with the power supply section. The different sections are referred to as HOT section and COLD section in the precautions below. 1. Do not touch the HOT section and the COLD section at the same time. You may receive an electric shock. 2. Do not short the HOT section to the COLD section. This could blow the fuse or damage parts. 3. Never measure the HOT section and the COLD section at the same time when using tools such as oscilloscopes or multimeters. 4. Always unplug the unit before beginning any operation such as removing the chassis. https://imgur.com/o5UrwLt https://imgur.com/X90zW4i Only 'ohm checking' I'm aware of: '0' - continuity/shorted infinite - open ------------------------- Location: Far, Far Away
(This post was edited by jts1957 on May 6, 2020, 3:25 PM)
