app37le
Feb 22, 2005, 5:25 PM
Post #3 of 3
(1903 views)
Re: [crawdaddy] Help on convergence tweak
Brian, Thx to your tips, I've been able to fine tune the convergence on my RCA P46924 46" rear projection TV (it might be similar with other RCA rear projection units). I would like to share the procrdure a bit more in details. 1) Turn on the TV by pressing the Power button on the front panel. Corse convergence needs to be adjusted (by using the remote unit) prior to step 2. This will give you a better reference to start with. 2) Hold the Menu key and press the Power button. (menu comes up on screen) 3) While still holding the Menu key, press Vol + key and the display with p0 (on the left) and v0 (on the right) comes up. Let go of the keys and hit Vol + or vol - to set v0 to 80. BTW, do you know what the other numbers are for? 4) Press Channel ^ to get the convergence "grid" displayed on screen. 5) A "yellow cross" is displayed at the center of the screen. Now use the remote unit for adjustments. The green arrow buttons are for moving the "cross" and the blue arrow button are for adjusting the red convergence. Up, down, left and right buttons are for respective adjustments. 6) Use the "next" button (on the center right side of the remote unit) for displaying the "blue cross". 7) Press the Power button on the remote when done. The whole process is time consuming (took me about 30 minutes) as convergence is adjusted one "square" and one color (red or blue) at a time. And you have to go back and forth to readjust and "fine tune." Just be patient, play some music or listen to your favorite TV channel while tweaking. If for any reason you run into problem and/or have a mess up picture. Press the "reset" key on the lower right of the remote unit. Once you press that, you should get back a fairly "viewable" grid pattern for adjudtment. Hope this is helpful for others.
