Apr 25, 2005, 10:35 PM
(1050 views)
Re: [skraj] Hitachi 27CX3BC- screen starts reduce size vertically and gets distorted
You are probably experiencing bad solder joint in the vertical circuit which is making intermittent contact. If you are handy with a soldering iron, it is an easy fix that you can do yourself. I would just touch up all of the solder joints on the vertical IC and that should do it. You might also want to check out www.FreeFlatScreens.com/?r=10948674 for an opportunity to earn a free replacement for this set with a little effort on your part.
