How does PDIM work? (Soyo backlight problem)
bloodchange
Dec 11, 2012, 1:27 AM
Post #1 of 2 (3510 views)
How does PDIM work? (Soyo backlight problem) Can't Post
I'm a newbie and I'm also new to flat screen TV's. (I've repaired a few CRT TV's before, but I'm not a pro.)
I'm trying to fix my Soyo MT-SYTPT3227AB that has a V144-JO2N backlight inverter board. I get sound, but no picture.
I'm getting power to the inverter board, but the lights won't light. I get 24V across each of the electrolytic caps. There is a twisted pair of green and yellow wires that connect to the OFF/ON pin and the PDIM pin (12&13). Both of them are at 5V (reference ground--not 5V between 12 and 13).
How does PDIM work? Is it either high or low (5V or 0V) or is it a range of voltage? (proportionate control) If it is the former, should it be at 5V with the backlight totally dimmed?
74f100
Dec 20, 2012, 6:34 AM
Post #2 of 2 (3421 views)
Re: [bloodchange] How does PDIM work? (Soyo backlight problem) [In reply to] Can't Post
Normally it goes high to turn on the inverter (5vdc or less).
Well, actually the pdim will vary depending on the video. The off/on is initially the important one, make sure it goes high and stays. If not, there is a problem with the main (or rare cases power supply). If both the on pulse and the pdim go high with 24vdc drive the inverter should light. If not it's a problem with the inverter or panel.
Ok, my fingers are tired typing.
Good luck,
Jim
HDMI not working
