Aug 31, 2004, 9:38 PM
Post #2 of 3
(1346 views)
Re: [TANK1] How to degas a Toshiba 36A50?
TVs have an automatic degaussing system which activates each time that you turn on your TV. Try turning the set off and on a few times letting it cool down between cycles and see if that does the trick. In a pinch, I have used an electric drill motor to degause a PIX. Just turn the drill on and hold it close to the face of the PIX. You should see a rainbow affect in its immediate vicinity. Move the drill in a circular motion around the face of the tube and slowly move it away before turning it off.
