Sep 30, 2012, 5:05 PM
Post #7 of 7
(14698 views)
Re: [TZ] How to disable child lock on Magnavox 27MS343S without remote
TZ;.... I do not have any electronics experience nor any instruments, but I can try and open up the TV. Due to the lack of experience etc , I do not recommend you open up the TV.... from what I have been reading, child lock disables all buttons on the front panel except the power button. 100% correct.... The fact that my TV's power button switch is not quite functional (when I press it in, it doesn't quite go in; seems like a loose connection; so I never quite used it, just used to unplug the TV when not in use and used vol to get it out of standby) maybe adding to the problem. IF that button is wedged in to the point that it is in the "on" mode always , then that would explain why the TV will not turn on...(Even with the remote..) This makes me wonder: should I first try to resolve the power switch button issue, and then maybe everything will be easier? Possibly... You will have to figure that out on your own... IF you can wiggle the pushbutton free , maybe , just maybe , you could free up the switch inside .... IF not , your best route would be to take the TV in to a HONEST , REPUTABLE & TRUSTWORTHY TV repair shop & get an estimate (Hopefully free ..) Do NOT take the TV apart as the controls (pushbuttons) are at the front of the TV & you have to remove the chassis to get at that panel.... Your call...... Good Luck........ Later....Ron.M........ Veteran & Retired TV technician
