Sep 9, 2004, 9:20 PM
(1069 views)
Re: [titan] JVC 32" is playing in Black and White
Occasionally, JVC tuners will go bad. Assuming that you are using the DVD input jacks which bypass the tuner, your description sounds like the soldered ground connections inside the tuner may have deteriorated and are making intermittent contact. Get an estimate from your local repair shop and then weigh the cost of repair vs cost of a new set to make a decision. You might want to check out www.FreeFlatScreens.com/default.aspx?referer=7509165 for an opportunity to earn a free replacement for this set with a little effort on your part.
