beaowolf
Sep 6, 2004, 7:33 PM
(2543 views)
JVC TV AV27920, sound cutting out
So the TV is ~6 yrs old, and after getting a power surge from a cable box I started to have the sound cut out. If I played with the input cable TV cable (no cable box used now) I could get the sound back, but sooner or later it would cut out again so that the sound was very low-but still on for all channels. There is only one board and by moving the input cable I also moved the wires that go to the speakers. So I sprayed the board with WD-40 where the speaker wires are plugged in to it and that solved the problem right away-but the sound still cuts out some times-so I spray again. Some times the sound cuts out and I switch to another channel and then back and the sound is fine. Any ideas?
