JVC distorted picture (click image) low resolution, blurred... NEED HELP, PLEASE!
joewandahayley
May 27, 2006, 1:16 AM
Post #1 of 10 (2419 views)
JVC distorted picture (click image) low resolution, blurred... NEED HELP, PLEASE! Can't Post
As you can see in the picture, the resolution is poor. This is a 3-year old JVC av-48wp74 48" projector TV. The picture showed perfectly without any problems whatsoever the first 3 months, then we started seeing the picture jump to this state shown below for a quick second, then back to normal. Three years later, it's in this distorted, low resolution mode all of the time. My husband & I just purchased a service manual for this model TV & has gone through pretty much every adjustment listed & still nothing. The picture shows like this all of the time with DVD, VHS, broadcast signal, or cable. We've seen several samples of distorted projection TV images, but not one comes close to our problem. Can anyone help us, please?
Wanda
May 27, 2006, 11:43 AM
Post #2 of 10 (2410 views)
Re: [joewandahayley] JVC distorted picture (click image) low resolution, blurred... NEED HELP, PLEASE! [In reply to] Can't Post
this picture looks solarized. Is this an lcd projection tv? If so I would guess the lcd engine is causing the problem.I dont recognise the model number. Not European I think
joewandahayley
May 27, 2006, 2:11 PM
Post #3 of 10 (2408 views)
Re: [techchris] JVC distorted picture (click image) low resolution, blurred... NEED HELP, PLEASE! [In reply to] Can't Post
First of all, thanks for your reply. Is a solarized picture a major problem or something we can correct? I've never seen anyone else with this problem. It's not an lcd projection screen. It has the three picture tubes with a mirror. We have the back off the unit right now & have no idea where to start to correct this issue. Thank you, TechChris.
May 27, 2006, 2:55 PM
Post #4 of 10 (2404 views)
if the fault was intermittent it may be a bad solder joint somewhere probably in the video processor . you could try prodding around with an INSULATED plastic stick to see if it can be made to come and go .also you could check to make sure no oil has leaked from one of the crt's onto the circuit boards.If you have a multimeter check the screen volts going to the crt's.Does the picture look the correct size?
joewandahayley
May 27, 2006, 3:19 PM
Post #5 of 10 (2403 views)
The picture shows normal size. My husband is checking on everything that you've suggested. We really appreciate this help!
Wanda
joewandahayley
May 27, 2006, 7:09 PM
Post #6 of 10 (2400 views)
I checked for loose wires, and did not find any, however during the self check it reports AOI 6 NG and YC 2 NG there are 2 settings that are quite different from the factory settings in the YC settings, but the service manual says do not adjust. Please advise.
Thanks,
Joe
May 27, 2006, 7:34 PM
Post #7 of 10 (2396 views)
YC2 no good suggests a problem in the chroma or luminance stage. the video processing is all done in the same module, normally one stuck upright on the main pcb,possibly in a screening can.it sounds like you may need a professional tech to look at this in your house, i will look up a01 6 if i can find a service manual.
Paulpablo
May 28, 2006, 12:42 AM
Post #8 of 10 (2388 views)
Replace husband with a good tech !
joewandahayley
May 28, 2006, 12:50 PM
Post #9 of 10 (2386 views)
Re: [Paulpablo] JVC distorted picture (click image) low resolution, blurred... NEED HELP, PLEASE! [In reply to] Can't Post
Miraculously, as the family arrived yesterday afternoon, the colors came back, the picture shows great now after several hours of warming up or touching something on the video processor with the plastic stick that you suggested. We turned the set off, then immediately back on, the color went back to that solar appearance, but for only 20 minutes this time. We cannot turn it off without losing the good picture so it will remain on. For now, my husband considers himself that "GOOD TECH" husband that any woman would love to have. Ha ha ha!!! If there's just something lose or if just needs to be warmed up, seems like we can save some money here. We still have work to do, but it'll have to wait til after the holiday. Thank you so much, TechChris, for your advice!!! Without you, we wouldn't have our screen tv this weekend to view!!! Highly appreciate!!!!
Wanda
May 29, 2006, 1:44 PM
Post #10 of 10 (2378 views)
If you cant induce the fault to appear by prodding or tapping then it maybe temperature related. so invest in an aerosol tin of electronics freezer spray and see if you can get the fault to appear by chilling components one at a time. its a long job but generally successful with patience.
