KDL 32L5000 Remote does not work
allen11584
Jun 28, 2011, 10:03 PM
Post #1 of 10 (14593 views)
KDL 32L5000 Remote does not work Can't Post
I have a Sony TV Model # KDL 32L5000. The remote all of a sudden stopped working. I have tried multiple universal remotes and nothing seems to work except the buttons on the side of the TV. I took the board with the IR receiver on it out of the TV( board # 1-857-331-21 H2 Board). Does anyone know how i could test the board to see if the IR receiver is bad. Or if there is a way to find the part number of the IR and I will replace that instead of replacing the whole board.
MoeS
Jun 28, 2011, 10:08 PM
Post #2 of 10 (14586 views)
Re: [allen11584] KDL 32L5000 Remote does not work [In reply to] Can't Post
Check if the original remote is working properly. Use the camera function of your phone. Push a button, you should see a flash on the screen of your camera.
allen11584
Jun 29, 2011, 1:36 AM
Post #3 of 10 (14578 views)
Re: [MoeS] KDL 32L5000 Remote does not work [In reply to] Can't Post
I have done that and the remote is fine. That is why i was going to see if i could just re solder another IR on the board, I just don't know where to get an IR like that one without a part number.
Jun 29, 2011, 8:34 PM
Post #4 of 10 (14557 views)
allen11584;....
I've not worked on this model , but , maybe , I can be of some help...
Most IR recievers have 3 pins...
Yours has 4 pins (IRM9100) , 2 of which appear to be connected together...
One is for B+ (Usually about 5 vdc) , one is for the output to the Microprocessor (Usually LESS than 5 vdc) & the 3rd is ground...
Check for B+ on one of the pins...
With the set on , have your meter (DVM on DC volts) hooked up to the other pin (NOT the ground pin) & hit any button on the remote...
You should see a voltage swing as you press on the button & stop when you release the button...
IF that happens , chances are that the IR reciever IS OK....
Getting a part number for just the IR reciever may be a problem...
Your best bet & easiest way is most likely to get the whole board....
(ShopJimmy has it listed for $19.83 but is out of stock.)
http://www.shopjimmy.com/...-331-21-h2-board.htm
Others I found are $50~$60+...(RIDICULOUS !!!)
Another ShopJimmy listing shows the EXACT SAME part IN STOCK for $24.95..
http://mnboards.shopjimmy.com/...-331-21-h2-board.htm
IF you insist on just getting the IR reciever (OR it actually checks bad) , the ONLY way to get that number would be to get the "Service Manual"...
But , I have to warn you that the service manuals for the new sets (LCD,LED & Plasma TVs) are verrrry skimpy with basic part numbers & some do NOT even have schematics....
So it will be a crap shoot if you get the manual & expect the part number...
Remember this;...
IF the IR IS putting out a pulse when you press a button on the remote , chances are that it's OK....
You most likely will have other problems that I can NOT help you with as I do NOT work on LED, LCD or Plasma TVs...SORRY....Unsure...
IF you have a small or no voltage swing then the chances are that the IR reciever is bad...
GOOD LUCK....Sly.....
Have a GREAT day & week....Sly....
Later...Ron.M....Cool....
(This post was edited by Ron.M on Jun 29, 2011, 8:40 PM)
allen11584
Jun 30, 2011, 2:38 AM
Post #5 of 10 (14547 views)
Re: [Ron.M] KDL 32L5000 Remote does not work [In reply to] Can't Post
Ron. M
Thanks you so much for the advice. I'm going to not even hassle with checking the IR to see if it works. Ill go the easy route you suggested and just buy the board from shop-jimmy that is the exact same model for $24.95.
But thank you so much.
Allen
allen11584
Jun 30, 2011, 12:41 PM
Post #6 of 10 (14540 views)
Ron. M.
I have ran into a little problem. I have tried to buy from shopjimmy.com but i am not a certified technician. Is there another way to go about buying this board?
thanks
Allen
Jun 30, 2011, 5:07 PM
Post #7 of 10 (14534 views)
allen11584;....
You REALLY NEED to do this FIRST !!!
You NEED to determine IF the IR reciever IS working OR NOT....
Otherwise IF the IR reciever is GOOD & you order & install the new board , you will have the SAME problem & wasted $25.00 + s&h....
We'll leave the "being pissed" part out....Wink...
Your call....
Also , I just checked on this link;=>....
And today it shows they're "out of Stock".....Damm !!!...Unsure...
It won't take but a few seconds to check the IR reciever....NOT a hassle....
Do you have & know how to use a DVM ????
Sonylistens
Jul 8, 2011, 4:02 PM
Post #8 of 10 (14494 views)
Hi allen11584,
My name is mike and I work for sony, I am sorry to read about your trouble with your remote and tv, please email Sonylistens@am.sony.com and include your info, product info, and serial number and a rep will get back to you with help.
-Mike
Jul 8, 2011, 4:25 PM
Post #9 of 10 (14492 views)
allen11584, Let us know how much their recommended servicer wants to "sock it to ya," for their help.
Repair man
Jul 8, 2011, 9:55 PM
Post #10 of 10 (14487 views)
Hello allen11584 -- I have that board & would like $15 for it. If you are interested just email me with your mailing address. You can find my email address by clicking on my user-name.
Learn Plasma TV Repair
_________________
Learn LCD TV Repair
