creekster
Unregistered User
creekster@comcast.net
Mar 7, 2003, 4:33 PM
Post #1 of 3
(483 views)
KP-43T70 I have codes but now what?
My KP-43T70 prjection TV turned off and is displaying a blinking code of four flashes. I have found that this means: 4 times, pauses and repeats Set turns off. Vertical failure (the horizontal could also cause this since the power for the vertical comes from the flyback) Possibles:(Vertical failure) Vertical Output failure IC001 damaged No vertical drive from IC301 No vertical B+ from flyback No horizontal drive I have checked the one fuse I found and it looks good. There is no visible discoloration and the filiment looks in tack. I would like to try and troubleshoot this myself.Before I call the repair man so I know what's going on. Any help would be appreciated. I am looking for a service manual and/or shematic for this model, as well as any and all advice and tips. The unit was made in 2000 and is used a few hours a day. Thank you in advance for your time in reading and replying to my pleas for help!
