davisflow
Oct 16, 2015, 8:55 PM
Post #38 of 49
(2873 views)
Re: [davisflow] LG 42cs570 shuts off after 10 seconds of powering on.
If Error is low when screen is on (lit), what happens if you were to keep it low with a third jumper, Error to ground? When I attach a jumper from error to ground(no other jumpers), with the cable plugged in, and turn the set on, it shows the main screen, then the screen turns off, but the power light stays lit, blue, indicating that power is on. If I hit the 'input' button on the remote, the blue light flashes indicating that it is receiving the signal. The set did not shut of automatically, I had to press the power button on the remote to turn it off. When I turned it back on, and the screen flashes on again, it was on a different input, indicating that when I pressed 'input' while the blue power light was on, the signal was received.
You would want to be able to see a single color screen if the screen stays on for more than a couple of seconds, to see if any area is dimmer than any other. I can't get the screen to stay on for more than 1 second, however, I took a close look at it a few times, and I do not see any dim areas.
