Jul 8, 2016, 4:40 PM
Post #4 of 7
(1530 views)
Re: [rtruett1] LG 55le5400 no back lights
The LGP4247-10 power supply board, with the AC connector positioned to your lower left, has a 24 pin connector (just across from the AC connector) to your lower right labeled 'P201' (just behind its top). Its pin-out chart is just below the connector, odd numbered pins on the left and even numbered pins on the right. The row of pins closest to the edge of the PCB are 'even.' IF it is this connector you're referring to, I don't see any pin marked 'Pw On 24v.' I see pin 1 marked 'PW on' & pin 2 (and pins 3 and 4) marked '24V'. ------------------------- Location: Far, Far Away
(This post was edited by jts1957 on Jul 8, 2016, 7:29 PM)
