LG TV no longer recieving signals even after changing to new antenna
flow32
Jan 22, 2019, 8:39 PM
Post #1 of 5 (1978 views)
LG TV no longer recieving signals even after changing to new antenna Can't Post
Last week i purchased a cheap antenna from ebay, after setting it up and auto tuning my LG 42LD450, it was able to recieve and pickup 60+ channels. A few days later, i noticed the increasing number of channels losing signals until another couple of days my TV stopped receiving signals all together. I tried auto tuning it again but it is no longer receiving any signals. I though that the problem might have been that cheap antenna so i purchased a new antenna with amplifier which is a lil bit more expensive. After setting it up and trying to auto tune the channels again, it still does not receive any DTV signals, even though it is receiving UHF channels. Can anyone help?
I also have tried restoring my TV to factory and moving my antenna closer to the window and higher but it did not make any difference.
(This post was edited by flow32 on Jan 22, 2019, 9:27 PM)
Jan 23, 2019, 5:09 AM
Post #2 of 5 (1959 views)
Re: [flow32] LG TV no longer recieving signals even after changing to new antenna [In reply to] Can't Post
Antenna = Directional ... or ... Hominydirectional?
Channels found have sufficient signal strength? Does this remain the same or decrease over time?
Can channels found be grouped into ie. Favourite Lists? Are they still in these lists when they can no longer be reiceved
flow32
Jan 23, 2019, 2:18 PM
Post #3 of 5 (1949 views)
Re: [jts1957] LG TV no longer recieving signals even after changing to new antenna [In reply to] Can't Post
-The new and old antenna is both Omni-directional.
-The channels found using the old antenna had very good signal strength, no flickers and no distortion on the image, however after a few days i noticed the increasing amount of channels having poor signal until a week later, most of the channels had no signal at all, which has caused me to buy a better antenna to replace the old one as i though it was the cause.
-Im not entirely sure now, since i did not group any of the channels into a list, however i can say that after auto tuning the channel using the new antenna, i noticed that the channels did not start from channel 1 but instead to channel 22. There was alot of channels missing and most have just skipped, for example: there was no ch.1-21 but ch. 22-26, exist but shows 'no signal'. i hope this makes sense.
Jan 23, 2019, 3:14 PM
Post #4 of 5 (1947 views)
I was looking for something a little better than a subjective opinion ... From user manual:
"When selecting DTV or Cable DTV input signal in Manual Tuning, you can view the on-screen signal
strength monitor to see the quality of the signal being received."
TV should be Factory Reset, antenna to be used should be connected and positioned ONCE. A auto tuning should be done Only once without antenna being changed or re positioned until all observations are finished.
flow32
Jan 23, 2019, 4:17 PM
Post #5 of 5 (1945 views)
I am aware of the signals strength being on screen and that it can be used manually to pick up a better signal, however i am not getting any frequency, instead i get "No signal". I tried it on both DTV and TV, the DTV gets "no signal" while the TV gets no result, i just keep on scrolling the "search" section and only gets noise on screen.
I also looked into my channel maps as you mentioned something about a "list" being saved after tuning, my channel maps for DTV, Radio and TV are all empty. I tried deleting any existing channels from the list but since there is none saved i could not do anything.
I did a factory reset yesterday before i made a post in this forum and it did not make any difference.
For reference, here are some picture i took during the troubleshooting i did.
Auto Tuning 1
Auto Tuning 2
Manual Tuning 1
Manual Tuning 2
Favorite group
